two-pipe heat exchanger modelling with thin wall approximation |
November 23, 2021, 09:01 |
a
Rep Power: 13 |
Hi there,
In order to model the heat transfer between two fluid flows of a simple straight double-pipe heat exchanger, we can model 4 cell zones: 1. outer pipe wall 2. outer pipe fluid 3. inner pipe wall 4. inner pipe fluid However, I am wondering whether we can assume a thin wall instead of the inner pipe wall, and just enter a thickness and conductivity of the wall, without modeling the conduction. I mean by only modelling two cell zones: 1. outer pipe fluid 2. inner pipe fluid and simply add an interface between the two cell zones and defining a thickness and conductivity. I ask this because I do not need the temperature profile or contour in the inner wall, but I need only the fluid flows behaviour. Thank you |
double-pipe, heat transfer, thin wall, two-pipe |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
Double pipe heat exchanger with SST k-w turbulence model | MStudent | FLUENT | 1 | May 21, 2016 03:31 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
