What is best model for modelling transitional flow in fluent?
Old   November 22, 2021, 11:36
Default What is best model for modelling transitional flow in fluent?
Ram N
nrram is on a distinguished road
I am trying to model a heat transfer flow in a pipe. I have two cases. The Reynolds number is in transitional region for both the case. For case 1, the Re is about 2400 and case 2, Re is between 3000-3800. What is the flow model in fluent that I can use to model these flow with higher accuracy?
nrram is offline   Reply With Quote
Old   November 26, 2021, 00:23
jsm
JSM
jsm is on a distinguished road
If you ask best turbulence model with higher accuracy for transitional Re flow, then I recommend to use LES or DES turbulence model.
If your geometry is simple, then you can use these models with highly refined mesh. Otherwise, you have to compromise the results accuracy by using transition turbulence models.
With regards,
JSM
jsm is offline   Reply With Quote
pipe flow, reynolds number, transitional flow, viscous model
Gamma-theta turbulence model for transitional flow kobe81 CFX 2 May 22, 2017 06:57
Scaling down Fluent Model - Multiphase Flow and DPM Injections salmanayon Fluent Multiphase 0 October 13, 2016 01:29
Difference between Fluent transitional model and CFX transitional model Anna Tian FLUENT 2 August 7, 2014 11:52
Is it possible to model natural convection in a 2D horizontal model in fluent caitoc FLUENT 1 May 5, 2014 14:32
What turbulent flow model choose in Fluent ja.maldonado1187 FLUENT 2 August 11, 2013 07:33
