Multiphase Problem with water and air over steel plate: Image attached
Old   November 18, 2021, 08:34
Default Multiphase Problem with water and air over steel plate: Image attached
Rabi Pathak
RabiArya is on a distinguished road
I have a steel plate where the bottom wall is heated. Above this solid plate, a water-filled zone is there which is contained by side adiabatic walls made up of steel. Above this static water zone, a zone filled with air is present. The air is incoming and outgoing as shown in the figure.
The air is modelled as a species with a combination of dry air+ water vapour.
The water is also getting evaporated based on pressure difference and vapour formed is getting mixed in the air zone.
Note : 3 frozen bodies are made in the design modeller and then all are made to form new parts.
Can anyone guide me on how to do this?
RabiArya is offline   Reply With Quote
Old   November 19, 2021, 00:56
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
seems like you've done it already isn't it?
so you have 2 zones solid and fluid. fluid is a mix of water and air.
after initialization patch water part of fluid zone with water = 1
set boundary conditions
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 19, 2021, 08:23
Rabi Pathak
No sir, there are 3 zones.
Zone 1: Solid(steel)
Zone 2: fluid(water)
Zone 3: fluid( dry air+ water vapour)
Zone 2 is static liquid is contained within walls
Zone 3 is air moving from inlet to outlet
I tried doing this, but I am not getting proper results. I am doing a steady state analysis. But the result are absurd.
Multiphase problem with multiple zones : Picture attached RabiArya Fluent Multiphase 4 November 19, 2021 08:48
problem with two phase flow (air injected in water) miles_davis OpenFOAM 15 March 31, 2021 10:36
How to use a UDF to set the volume fraction in the cells next to a wall? DF15 Fluent UDF and Scheme Programming 33 August 20, 2020 14:36
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 20:24
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
