Population Balance Model in Fluent - Surface area of changes due to diffusion of part |
November 13, 2021, 19:24 |
Rep Power: 11 |
I am trying to simulate particles motion in laminar flow using a monodisperse population balance model that uses three transport equations to track number (N_agg), surface area (A_tot), and mass of particles (C_tot). I have used three UDSs to implement the transport equations. The diffusion of particles (due to gradient of N_agg) changes N_agg, A_tot and C_tot.
The problem is that the diffusion of particles is only associated with second derivative of N_agg (d2N_agg/dx2), so the transport equation for N_agg can be expressed in UDS standard form. BUT, the transport equation for A_tot, and C_tot does not follow the conventional form. So, the effect of particles diffusion (due to N_agg gradient) becomes source term for A_tot and C_tot. I calculated the RHS expressions using DEFINE_SOURCE for A_tot and C_tot, but I always get diverged simulations. I couldn't find any similar example in UDF manual. |
November 14, 2021, 19:21 |
Rep Power: 11 |
Any suggestions?
population balance model, uds diffusive, uds source term |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
surface to volume ratio in non-equilibrium porous model of fluent | Weiqiang Liu | FLUENT | 6 | June 15, 2020 06:22 |
How To Create Fowcs William Hawkings Surface in Fluent? | marinkobezu | FLUENT | 7 | October 25, 2018 10:51 |
Population Balance Model Fluent | furqanrk | Main CFD Forum | 0 | April 6, 2016 04:12 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
