November 10, 2021, 02:03 |
UDF for k-omega SST
Rep Power: 5 |
I am simulating multiphase problem of cavitation with k-omega SST turbulence model and I am trying to make UDF to reduce the turbulent visocosity, especially in areas with low void ratios. I have already done it for k-epsilon RNG model (and it worked well) according to: COUTIER-DELGOSHA, O., R. FORTES-PATELLA a J. L. REBOUD. Evaluation of the Turbulence Model Influence on the Numerical Simulations of Unsteady Cavitation. Journal of Fluids Engineering. 2003, 125(1), 38-45. ISSN 0098-2202. Available at: doi:10.1115/1.1524584 However, I am struggling with the UDF function for k-omega SST. When I try to interpret the function in Fluent, it says: line 31: unknown data op (ld.pointer) in block data. Nonetheless, there is no line 31. I have already checked for semicolons and parantheses... The equations for k-omega SST model, I have used, are described e.g. in Appendix of this article: https://pdfs.semanticscholar.org/767...640.1634903874 And here is my function: #include "udf.h" #include "mem.h" #define mojeMax(a,b) (((a)>(b))?(a)b)) DEFINE_TURBULENT_VISCOSITY(cavitation_mu_t, c, t) { int n = 10; Thread** pt = THREAD_SUB_THREADS(t); real a1 = 0.31; real k = C_K(c,t); real y = C_WALL_DIST(c,t); real omega = C_O(c,t); float OMEGA[3] = {C_DWDY(c,t) - C_DVDZ(c,t), C_DUDZ(c,t) - C_DWDX(c,t), C_DVDX(c,t) - C_DUDY(c,t)}; real OMEGA_V = pow(SQR(OMEGA[0]) + SQR(OMEGA[1]) + SQR(OMEGA[2]), 0.5); real arg2 = mojeMax((2-pow(k,0.5)/(0.09*omega*y)), (500*0.0000010034/(SQR(y)*omega))); real F2 = tanh(SQR(arg2)); real nut = (a1 * k)/mojeMax(a1*omega, OMEGA_V*F2); real rhoM = C_R(c, t); real rhoL = C_R(c, pt[P_PHASE]); real rhoV = C_R(c, pt[S_PHASE]); real f_of_rho = rhoV + pow((rhoM - rhoV)/(rhoL - rhoV), n)*(rhoL - rhoV); return f_of_rho*nut; } Do you know, where the problem could possibly be? Thank you. |
udf; k-omega sst |
k and omega at inlet for k-omega SST | driu | OpenFOAM Running, Solving & CFD | 10 | March 5, 2021 10:48 |
K omega SST equations in Openfoam | tom.opt | OpenFOAM | 2 | May 6, 2020 09:41 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 12:50 |
Modeling the reynolds stresses and turbulent heat fluxes by sst k Omega | medaouarwalid | Main CFD Forum | 3 | January 5, 2018 20:12 |
The reason of the substitution of Omega by S in the SST k-omega model? | huangxianbei | Main CFD Forum | 2 | January 1, 2018 20:14 |
