November 9, 2021, 08:40 |
Supercritical Nitrogen Simulation
Furqan Ahmed
Has anyone done the simulation of injection of nitrogen in supercritical chamber IN FLUENT? I want to do this simulation in Fluent by using the real gas model but am having a hard time setting up the model. The link to the paper is: https://commons.erau.edu/cgi/viewcon...75&context=edt If someone has done this please help. My Ansys Fluent settings are: Pressure Based Solver Transient Energy Equation On LES SRK Equation of State Pressure velocity coupling Scheme Coupled Gradient Node Based 2nd order Accuracy And boundary conditions being: Inlet Nitrogen with 5.04 m/s The outlet of Normal atmospheric pressure Assigning my cells as 4 MPa pressure Regards, Execrabilis Last edited by Execrabilis; November 9, 2021 at 10:53. |
November 9, 2021, 14:55 |
Lorenzo Galieti
Rep Power: 12 |
What is your problem? Setting up SRK is very easy, I don't get the issue, you just choose something different from ideal gas
November 9, 2021, 23:44 |
Furqan Ahmed
First of all thanks a lot for replying.
I tried running the simulation and my simulation ran fine but when I checked the result there was no density variation and the stream of nitrogen was completely different from what it is in research paper. Then there is the problem that in the research paper he is taking the density of nitrogen at inlet to be different and in the chamber to be different. And should I assign the 4 MPa to the chamber only or the complete domain. The final problem is that of the outlet. I don't know what to assign the outlet as. You can look at this paper: https://www.sciencedirect.com/scienc...96844612003075 |
Simulation of supercritical flow in fluent | dexter | FLUENT | 2 | September 20, 2019 06:24 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 02:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 15:06 |
High pressure nitrogen discharge simulation in Fluent | jzapatau | FLUENT | 0 | October 2, 2016 17:54 |
Simulation of high pressure diesel injector - all phases compressible with cavitation | fivos | CFX | 4 | July 30, 2015 06:48 |
