Time Scale Factor - Any negative effect to setting to large?
Old   November 5, 2021, 10:37
Default Time Scale Factor - Any negative effect to setting to large?
David
rudyy is on a distinguished road
I have a simulation with a very large temperature distribution (between room temp and about 1500 C). The computational domain is a cylinder with some internal hardware about 70 inches long a few inches in diameter. There are some very low flows going through the cylinder (laminar regime).
Flow velocities stabilize quickly, but temperatures usually take a very long time to stabilize. With with time scale factor set to 1 usually I have to leave it overnight to get any result. Recently I got the courage to bump the TSF up to 10, then 100 and then 1000. Now my strategy is as follows:
5 - 10 iterations with TSF = 1
Bump TSF to 100 (or 1000) and iterate until temps start to stabilize
Reduce TSF to 1 and iterate until convergence
Is there any "risk" of bumping the TSF like this? It has been an effective way to converge faster (~ 200 iterations vs. 2000+ iterations) and speed up my work, and the results appear reasonable.
Thanks in advance
rudyy is offline   Reply With Quote
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
