Multi component two phase flow
Old   November 1, 2021, 05:30
Default Multi component two phase flow
MA
fan01 is on a distinguished road
I want to model a two phase flow (vapor & liquid) with two components. Both components are miscible and at steady state the two fluid complete mix and becomes a single phase. The system is isothermal, so i am neglecting energy equation. The fluid flow is governed by continuity, momentum and species equation.
which of the two phase model can I use to solve this problem in Fluent or CFX? VOF method is not applicable to this problem since there is mixing and the interface vanishes after a while.
mechanism governing interfacial transfer between the phases include dissolution of the gas phase into the liquid phase and vaporization of the liquid phase into the gas phase.
fan01 is offline   Reply With Quote
Old   November 1, 2021, 10:37
Mandeep Shetty
granzer is on a distinguished road
Mechanisms governing interfacial transfer between the phases include dissolution of the gas phase into the liquid phase and vaporization of the liquid phase into the gas phase.
I am new to this too. This sounds like a multiphase flow with species transport in Fluent So maybe you should try VOF with species transport since initially the problem requires interface tracking.
granzer is offline   Reply With Quote
Old   November 1, 2021, 10:48
MA
Thank you for suggestion.
Old   November 1, 2021, 17:16
Lorenzo Galieti
LoGaL is on a distinguished road
The problem is exactly that at the beginning of your simulation you will need to use a VOF like technique, while later not. It’s very tricky simulation.
Perhaps mixture model can work. Also, if you expect at one point one of the fluids to be much more diluted than the other, could be worth looking also at VOF to DPM. Again, only if one is very diluted.
But again, this is tricky stuff I think
LoGaL is offline   Reply With Quote
Old   November 2, 2021, 07:08
MA
I expect that at a critical point, which is defined by the pressure and mass fraction of the mixture, the vapor phase becomes completely miscible with the liquid phase. And the gas phase vanishes away remaining just a single liquid phase containing both components.
Old   November 2, 2021, 08:08
Mandeep Shetty
You can try VOF model with phase interaction. Else try Eulerian model too if you have access to the computational power to run it..since Eulerian model is much more general and can work as both VOF and Mixture model.
cfd, cfx, fluent, multicomponent mixture, two phase flow
CFX Modelling 3 Phase flow with particle transport fluid and particle transport solid amon CFX 4 February 25, 2020 16:55
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
How to simulate a multi phase flow striking a surface and causing it to wear?? pankajbhatter9 FLUENT 0 November 2, 2013 14:19
How to simulate a multi phase flow striking a surface and causing it to wear?? pankajbhatter9 Main CFD Forum 0 November 2, 2013 14:11
High Speed multi phase flow jonita Macyte Main CFD Forum 0 March 19, 2010 07:46
