porous medium thermal analysis with two fluid flow |
Madelina
Rep Power: 6 ![]() |
I am trying to perform transient thermal analysis inside a porous medium. There are two fluids flowing inside the porous medium, both at different temperatures. I need to calculate the temperature change of both the fluids and the porous medium with respect to time. I have three energy equations to solve for three temperatures (coupled). My initial thoughts are to use UDS and non-equilibrium thermal model. Is this the correct approach to this problem. Would appreciate if anybody could share some example or point me to the right direction. Thank you, ymd |
Thermal non-equilibrium porous media model with conjugate heat transfer | Hexahedron | FLUENT | 9 | February 22, 2023 02:55 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
thermal stress analysis with fluid? | sheaker | FLUENT | 0 | April 20, 2018 16:32 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
thermal couple boundary condition between porous and fluid regions | atoof | OpenFOAM Programming & Development | 2 | June 7, 2017 19:44 |
