change outlet to inlet periodically
Old   October 20, 2021, 07:05
Default change outlet to inlet periodically
Erfan
erfan2000 is on a distinguished road
Hello
I have a problem with Ansys fluent, I have a pipe and I want to change the flow direction periodically in every 400s, in other words, I want to change the inlet to outlet after 400s and assign its last conditions to the former outlet for the next 400s and change condition to the first after that and repeat this procedure.
thanks
erfan2000 is offline   Reply With Quote
Old   October 20, 2021, 15:56
Lucky
1) Are you familiar with changing these settings using the GUI manually? Do it at least once
2) Learn how to do these using the text commands that you input into the TUI
3) make a journal or use execute commands to run the script you generated from 2)
Also, a forewarning. The first time you 1) I predict it will blow up in your face.
Old   October 20, 2021, 16:10
Erfan
thanks a lot
I'll try to learn how to work with TUI
inlet, outlet, periodic, reverse
[ICEM] Can same edge act as Inlet and Outlet? Wingman ANSYS Meshing & Geometry 0 February 4, 2017 18:16
flow around a circular cylinder with velocity inlet and outflow outlet shuoxue OpenFOAM 1 March 3, 2014 11:42
flow around a circular cylinder with velocity inlet and outflow outlet shuoxue OpenFOAM Running, Solving & CFD 0 November 2, 2013 05:32
Inlet & Outlet Velocity BC issue naiter OpenFOAM 3 December 19, 2012 08:14
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
