Fluent TUI command - mechanical option in CFD solver
Old   October 15, 2021, 07:28
Question Fluent TUI command - mechanical option in CFD solver
Mickael Perrin
mperrin is on a distinguished road
Hello there,
I am facing a problem using fluent with TUI command on a calcul center. I run a basic 2D CFD problem : rectangular fluid flow exchanging heat with a rectangular solid.
Until now, i was using Ansys 18.1 to prepare my .cas file. I work now with 2021 R1 with th same journal file i created.
However, current simulation doesn't work. As soon as my .cas file is opened, i get these waring messages :
Warning: property-info: unknown property: characteristic-vibrational-temperature
Warning: property-info: unknown property: atomic-number
Warning: property-info: unknown property: struct-youngs-modulus
Warning: property-info: unknown property: struct-poisson-ratio
I checked up my solver in meshing and it is clearly set up on 'CFD solver'. In fluent, 'Energy' in on and 'Viscous' is laminar. Everything else is off.
Can someone explains to me why do these mechanical caracteristics are 'on' and how can i block them ?
Please if you know anything, help me
Thank you
Mickael
mperrin is offline   Reply With Quote
Old   October 15, 2021, 11:16
Lucky
Your v18 .cas contains these declarations (somehow) and is being read into a v19 case. So you don't actually need to turn it off. With regards to this specific warning you can totally ignore it. But it is usually an indicator that you case setup is more complex than you can handle and pretty much a guarantee that something else is actually broken that you will not notice, which seems to be the situation...
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 07:33
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
