Finite Rate Chemistry not convergence for Hypersonic Flow
Old   October 13, 2021, 04:12
Post Finite Rate Chemistry not convergence for Hypersonic Flow
dxb
DuXB
dxb is on a distinguished road
The general solver and model settings I'm using are:
• Fluent 2021 R2
• Density-Based Solver, Steady-State
• Energy Equation On
• Two-Temperature Model
• k-w SST Turbulence Model
• Discrete Ordinate Radiation Model
• Species Transport, Volumetric Reactions, air-2species-nitrogen, Finite-Rate/NO TCL
• Pressure far Inlet,pressure Outlet BCs, Wall BCs
• Boundary Turbulence Specification: I = 0.05%, Turbulent Viscosity Ratio = 1.0
• Calculating in Absolute Pressure (0 Pa Operating Pressure)
• AUSM Gradient Method
• All equations first order
• Solution Steering - Hypersonic, FMG Initialization
• Courant Number:0.1-1-5-10;
When not open species reactions modle,it convergenced;after open reactions modle,it not convergence and "Divergence detected in AMG solver: TWOTE-eq Error at host: floating point exception".
If you have some tutorials or experiences, please help me solve this problem,thank you.
dxb is offline   Reply With Quote
fluent, hypersonic, species reactions
Finite Rate Chemistry Setup for Hypersonic Flow AdeeMij FLUENT 25 October 20, 2024 17:27
Solar heater flow rate, natural convection convergence Arttis FLUENT 0 March 23, 2017 13:24
Flow rate restriction simulation set-up siw CFX 4 February 16, 2016 13:15
two fluid, volumetric/mass flow rate at different volume fractions Veronique Pe CFX 2 November 26, 2014 06:30
Finite chemistry rate and multiple step marazn CFX 0 August 28, 2013 07:11
