Rep Power: 6 ![]() |
Hello everyone,
It is my first time simulating a helicopter rotor in hover. I want to re-create the case of the Caradonna Tung rotor. I am using 1 blade and periodic interfaces. the domain is a half cylinder with the inlet at the top and outlet at the bottom. For helicopter's in hover, they give the tip mach number and rpm. I use the RPM for the rotating fluid conditions. However for the inlet, I don't know if i should put the Tip speed or it should be 0 ? If the inlet speed is 0, then where to enter the tip mach number condition. Thank you |
helicopter rotor, hover |
Boundary Condition for Helicopter Hover | ChopraAbhi | Main CFD Forum | 1 | July 29, 2020 00:59 |
Optimization of helicopter rotor blade | Hybrid | SU2 Shape Design | 0 | December 11, 2016 19:52 |
appropriate software package for 2d helicopter blade modelling | cvcdcvcd | Main CFD Forum | 7 | February 12, 2016 20:33 |
Helicopter Rotor in Hover - Pressure Farfield Boundary Conditions | mjforsteruk | FLUENT | 3 | January 8, 2015 02:47 |
CFD of a helicopter rotor, solidworks? Ansys? | Elipsfire | Main CFD Forum | 0 | February 21, 2010 04:56 |
