Inflation layer cells deformation when using the Sliding mesh Technique |
October 2, 2021, 16:12 |
Kamyar
Rep Power: 8 |
Greetings,
I'm trying to simulate a 2d VAWT case using sliding mesh in Ansys fluent. The problem is that after 2 or 3 rotations, The solver diverges, and the reason is that there is deformation in the boundary layer cells, which is confusing. I would be glad if anyone could help me with this matter. I use the check mesh option before starting the transient run, but there is no problem with the mesh; the problem occurs after the rotor zone rotates and the Inflation layer cells deform when using the Sliding mesh Technique. Last edited by kam96; October 2, 2021 at 17:51. |
fluent, sliding mesh method, vawt wind turbine |
[snappyHexMesh] snappyHexMesh stuck when snap is turned on | yukuns | OpenFOAM Meshing & Mesh Conversion | 3 | February 2, 2021 14:05 |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 09:26 |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 20:34 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 04:21 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
