UDF for recycle particle
Old   October 2, 2021, 14:53
Default UDF for recycle particle
Pensylvania
khayrulbuet13 is on a distinguished road
Hi good people,
I am trying to simulate a filter with 90% efficiency. So I am using 2 UDF. DEFINE_DPM_BC for killing 90% particle that touches the outlet boundary and DEFINE_DPM_SCALAR_UPDATE to update the position of particle from outlet to inlet for recycling the 10% particle. Till now everything works fine. But It seems I also need to update the velocity because once the particle recycled they continue to move towards the negative x-direction.
I tried to fix the issue by updating the velocity also but it is not working. I tried with P_VEL(p)[1] = positive and negative value. but for both of the cases, the particle moves towards the negative y-direction.
** here I am attaching my UDF
Can you please take a look and help me in this regard?
#include "udf.h"
#include <stdlib.h>
#include <time.h>
DEFINE_DPM_BC(bc_reflect,p,t,f,f_normal,dim)
float my_rand,init_vel;
init_vel = - 0.272;
srand ( time(NULL) );
my_rand=rand() %100;
if (my_rand <= 1)
return PATH_END;
else
P_VEL(p)[0] = 0;
P_VEL(p)[1] = init_vel;
return PATH_ACTIVE;
DEFINE_DPM_SCALAR_UPDATE(recycle_particles,c,t,ini tialize,p)
FILE *fp;
float temp_rand, pos_rand, inlet_max;
inlet_max = 0.4;
temp_rand = rand() % 100;
pos_rand = (temp_rand/100)*inlet_max;
if (P_POS(p)[0] <= 0.4 && P_POS(p)[1] <= 0.7)
P_POS(p)[0] = pos_rand;
P_POS(p)[1] = 0.75 ;
File Type: c bcvel.c (703 Bytes, 2 views)
khayrulbuet13 is offline   Reply With Quote
Old   October 11, 2021, 20:59
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
I don't have much experience in DPM, but
shouldn't you modify velocity in update_scalar macro, as DEFINE_DPM_BC seems to be a boundary condition?
// your code
P_VEL(p)[0] = 0;
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
dpm, particle, udf
UDF for particle interception with pt_termination fortran routine abcdefgh CFX 6 October 6, 2019 14:30
Problem with a simple UDF to calculate cell-averaged particle values kmayank FLUENT 1 January 18, 2011 02:40
Move particle in UDF Henrik FLUENT 5 July 29, 2008 11:55
HELP! HELP! For udf of particle body force!!!! zhaoh FLUENT 0 February 5, 2007 05:10
udf about particle concentration--who can help me? zhaoh FLUENT 1 January 17, 2007 12:46
