Can't get combustion to work
Old   September 24, 2021, 06:25
Default Can't get combustion to work
Khadorna is on a distinguished road
Hi !
I have been trying to simulate combustion with the reduced GRIMECH files provided by fluent. However, when I try to simulate combustion, temperature does not rise. Im using k-eps. and Eddy Disipation to simulate combustion.
It consists of a circular 2D chamber where hydrogen enters into the air-filled chamber, and then should proceed to combust. I tried patching the temperature in the chamber to around 2000K, but it does not start the combustion either, the temperature gets reduced eventually.
When I try the same simulation, but using instead the Hydrogen-Air mixture given by Fluent drop-down list, combustion seems to work properly, but I need Grimech in order to get to better degrees of precission and NOx calculations.
When I loaded the kinetics, thermo and transport files from fluent I got: "Error: %set-material!: material not foundError Object: #f" Is it relevant? Should I take any more care into the kinetic loading? Should I import the thermo.dat file into the Thermodynamic Database File in the species tab? Is there anyway to kickstart the combustion appart from patching?
Thank you in advance for your help
Khadorna is offline   Reply With Quote
combustion, grimech
[Salome] problem with work flow: freeCAD => Salome => cfMesh mmohaqeqf OpenFOAM Meshing & Mesh Conversion 3 February 22, 2023 05:00
combustion does not work in my valveless pulsejet jabuor FLUENT 7 May 26, 2020 12:36
Non premixed combustion - combustion chamber pressure Gadders FLUENT 2 January 14, 2020 15:28
A role of combustion modeling in flow solver? Yoon Main CFD Forum 0 November 26, 2006 13:00
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
