Age of air calculation divergence
Old   September 20, 2021, 13:08
Default Age of air calculation divergence
e22rico is on a distinguished road
Hello, I have ran a few different HVAC simulation models with the inclusion of S2S radiation model, and with air density as "incompressible-ideal-gas".
I am using the following UDF to calculate age of air.
#include "udf.h"
DEFINE_DIFFUSIVITY(mean_age_diff, c, t, i)
return C_R(c,t)*2.88e-05+C_MU_EFF(c,t)/0.7;
DEFINE_SOURCE(mean_age_source, c, t, dS, eqn)
dS[eqn]=0;
return C_R(c,t);
I run the uds in transient after my models have converged with all other equations turned off. It converges perfectly for one of my models which was run with a constant density instead of "incompressible-ideal-gas". Otherwise it diverges. The age of air (volume average) jumps between really high positive and negative numbers.
Any idea on how to calculate it for the incompressible-ideal-gas cases?
e22rico is offline   Reply With Quote
aoa, fluent, hvac, udf
Age of Air Function Object b.simpson OpenFOAM Post-Processing 6 August 12, 2024 04:10
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 07:33
Two Phase Flow In Vertical Pipe stonepreston FLUENT 2 October 31, 2017 09:35
Mean Age of Air Convergence msmith Main CFD Forum 1 December 16, 2013 23:59
