Can a chamber be "pre-filled" with another fluid? |
September 20, 2021, 07:06 |
Rep Power: 5 |
Hello !
I've been trying to search information about this issue, but I have not been able to find an answer. It is a simple question, is it possible to have a chamber pre-filled with a fluid (air in this case) and then inject another one into it, with the air already in the chamber? I want to see how a flame expands in a combustion chamber, and when having velocity inlets to get the species in, the flow for the fuel is altered. Thank you in advance for your insights |
September 20, 2021, 09:45 |
Lucky
Rep Power: 66 |
Yes. You just set up the proper initial conditions. The details changes a little bit depending on what is your combustion model but it still comes down to initialization.
It's actually harder to do a simulation where the chamber is empty. |
September 20, 2021, 13:51 |
#3 | |
Rep Power: 5 |
And how could it be done? By patching the species inside the chamber? Sorry for the novice questions, but thank you so much for your time. |
September 20, 2021, 15:27 |
Lucky
Rep Power: 66 |
You just specify it as initial conditions.
It can be done with patching as well but patching is a tool for overwriting fields after-the-fact. You don't need to patch if you just do it correctly the first time. To be more specific, you need to at some point specify the mass fractions of individual species or fuel/oxidizer depending on your species transport model and/or combustion model. |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
Condensation of water vapor to water | visitor | CFX | 7 | June 7, 2019 19:25 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 06:07 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 18:19 |
