Can't select species in fuel inlet?
Old   September 20, 2021, 07:02
Default Can't select species in fuel inlet?
Khadorna is on a distinguished road
Hi !
I'm trying to process a 3D cyllindrical combustion chamber, where I want to inject some fuel via a fuel velocity inlet into the chamber where there is an air inlet and an outlet both being also velocity inlets at the "tops" of the cylinder and the fuel inlet being a small cube embedded into the side of the cyllinder.
However, when I try to select the species for the fuel inlet, nothing pops up, like it is unselectable. Why is this happening? I can select species for the air inlet, but not for the fuel inlet. Is it a problem with geometry?
Thank you all in advance
Khadorna is offline   Reply With Quote
combustion, cyllinder, fuel, species
How to specify species at pressure inlet? ansys_matt OpenFOAM Pre-Processing 0 March 16, 2021 17:43
How to specify inlet species in Ansys Fluent 2019 R3? obi FLUENT 0 February 24, 2021 14:46
Adjuting oulet pressure till inlet pressure reaches a certain value in timestep pvpnrao OpenFOAM Running, Solving & CFD 2 September 11, 2018 11:14
Hydrogen Fuel Injection in Inlet for Hypersonic Propulsion Rajan Bhandari FLUENT 0 July 19, 2018 02:49
inlet boundary conditions species transport richard FLUENT 2 August 20, 2008 08:25
