Fluent GPU processing
Old   September 16, 2021, 01:29
Default Fluent GPU processing
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
Hello
Which types of simulations GPU is supported in Fluent ???
I have HPC on 10 threads. In my case my settings are 7 CPU and 1 GPU. I have nvidia quadro p4000 8GB. So If I go transient simualtion with coupled method my GPU is below 1 % activity.
Do U have any recommends for GPU supports in Fluent .
Which type of methods /simulations I need to turn on to use my GPU ???
Best regards
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD)
https://howtooansys.blogspot.com/
Martin_Sz is offline   Reply With Quote
Old   September 16, 2021, 10:00
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
By default, GPU acceleration remains disabled for Fluents SIMPLE solver. No matter what you enter in the Fluent launcher. Because it is not well suited for GPU acceleration. You can force it on with console commands, but it will only make the solver run slower.
It should work out of the box e.g. with the coupled solver. And a bunch of others, I assume they are still expanding and improving this feature. It's been a while since I checked. See also https://www.nvidia.com/en-us/data-ce.../ansys-fluent/
A side-note on the Quadro P4000: it's great for FP32 (5.3 TFLOPS), but the double-precision compute performance (166 GFLOPS) is nothing to write home about. Something to keep in mind for your benchmarking. This also means that GPU utilization is not the best indicator for how well GPU acceleration is running. Better compare run times with GPU acceleration on/off.
flotus1 is offline   Reply With Quote
how to run fluent from matlab without using aas toolbox? artemis96 ANSYS 7 May 23, 2022 13:16
Save images using Fluent in batch processing mode dixitked FLUENT 8 August 29, 2019 13:25
[Resolved] GPU on Fluent Daveo643 FLUENT 4 March 7, 2018 09:02
parallel processing Fluent 6.3.26 ck3 FLUENT 6 October 30, 2013 01:44
FLUENT Parallel Post Processing john_cse FLUENT 0 October 20, 2011 06:49
