September 13, 2021, 11:29 |
Problem using water as fluid
Rep Power: 8 |
Hi, I am trying to simulate 2D NACA0012 . I have fixed Re=1000. My mentor told me that Cd and Cl should be the same when we compare air or liquid by fixing Re. But I am getting problem while using water-liquid. I have viscosity 0.001003, density 998.2, c=1 and velocity is 0.001005 implies Re=1000. But the results are not same. Can anyone let me now where I am wrong. What should I do? Thank you!
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 05:03 |
No conjugate heat transfer between solid (cast iron) and fluid (water) | Rajaero | Main CFD Forum | 1 | August 23, 2018 14:01 |
FSI: Pressure and Normal Force don't match with expected values | Geraud | CFX | 6 | August 21, 2012 16:34 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 02:40 |
Water vapour condensation in CFX-5.7.1 | hdj | CFX | 1 | November 27, 2005 08:15 |
