Custom field function in UDF
Old   September 11, 2021, 08:59
Default Custom field function in UDF
bagh fay
baghfay is on a distinguished road
Hi
basically i have created a custom field function within Fluent using the GUI and given it a name
within flent i can use it plot it and even do more calculation with it
however my problem is i want to refer to it within UDF but i do not know the name associated to it
for example pressure on a face can be referred using F_P(f,fthred) so i need something similar like F_custumFunctionName(f,fthred) but using the created custom function name returns error as it is not recognized and hence wondering what is the variable name associated with the created custom field functions and if there is any way to refer o it within a UDF
thanks and best regards
baghfay is offline   Reply With Quote
Old   September 13, 2021, 07:57
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
I don't think, there is a way to use custom fields from UDF.
But any custom field is based on variables available from UDF, so you should make the same custom filed but within UDF. You may store it's value in udmi variable, and plot it later
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Custom field function object from wallHeatFlux HorstvanGrass OpenFOAM Post-Processing 1 August 3, 2021 13:28
Writing custom function of flow field at every iteration sap_92 OpenFOAM Running, Solving & CFD 0 June 20, 2020 18:16
Can i take contours from Custom field function i defined ? rahulohlan FLUENT 3 April 18, 2017 14:39
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
