Repeat occurrence of negative nut
Old   September 9, 2021, 03:38
Default Repeat occurrence of negative nut
Adithya
Adithya_11 is on a distinguished road
Hello
I have asked a similar question previously but received no help. If someone could help me, it would be much appreciated.
I am simulating an aircraft body with SA turbulence model.
I believe my settings are good as they are based on recommendations from literature. My simulations converge well for my baseline model which has 1 body removed (an aft intake aboove the fuselage).
My problems begin when i add this body. The junction between the body and my fuse causes the prism elements there to become highly skewed.
Occassionally, in my iterations, i get messages that negative nut was calculated in around 2 to 7 cells. These are happening even at 5000 iterations.
Is this a problem? what will happen if this message occurs in my last iteration and the dat file that is written has these negative values?
Moreover, my continuity and nut residuals do not decrease below 1e-5 when i use the updated model. any suggestions on how i can decrease them and achieve tolerance of 1e-6?
Or, is this happening because there is some periodic separation and reattachment? it is a steady state sim. for the baseline model which has no problems, it converges within 3000 iterations.
My energy equation is on as i have ideal gas and sutherlands' law defined for air,
Adithya_11 is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
