Solution Animation
Old   August 31, 2021, 02:07
Default Solution Animation
RF_
Aref
RF_ is on a distinguished road
Hi
I have a problem for saving HSF file of "solution animation".
I set all the parameters in solution animation (specially the desired animation object) . But recently, a problem has arisen. I have defined 4 different animations (Anim1, Anim2, Anim3 and Anim4) but during the calculations animation objects (contour1, contour2, contour3 and contour4) of the defined animations are changed after some timesteps. for example; in the final file of Anim1, at the beginning there is some frame of contour1 but after them, another contour is shown (for example contour3).
Thanks for your attention
RF_ is offline   Reply With Quote
Solution Animation Error Jacob_Bing FLUENT 2 July 28, 2022 09:10
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Solution in animation in Tee fitting zeeshan2k6 Main CFD Forum 0 January 2, 2018 07:31
Steady State Solution animation rmageddon FLUENT 1 April 19, 2014 01:38
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 08:51
