FLUENT UDF for parallelization
Old   August 27, 2021, 12:55
Default FLUENT UDF for parallelization
Cooper24 is on a distinguished road
I am new to writing UDFs and new to coding itself in general. I have written a UDF for adding some source terms in my model. I use 10 cores on my PC for FLUENT in parallel. My UDF compiles and the simulation is also running.
Today, I learnt about something called parallelization of UDF. As I understood, the UDF should be parallelized for using multiple cores by adding some special commands in the UDF. I do not have any special commands in my UDF related to parallelization or number of cores to be used. Is it that my simulation is still running in serial even after selecting 10 cores on Fluent startup? As I said that my UDF compiles without error and the simulation is also running. Do I need to make changes in my UDF?
Cooper24 is offline   Reply With Quote
parallelize udf
Fluent UDF for moving laser heating of a solid block Cooper24 Fluent UDF and Scheme Programming 7 July 9, 2021 06:56
Problem running fluent with udf on batch tobi b. Fluent UDF and Scheme Programming 3 April 14, 2016 14:54
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 11:16
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 11:57
