What is the difference between different Species Transport model in Supersonic
Old   August 26, 2021, 23:02
Default What is the difference between different Species Transport model in Supersonic
iiran
ranxiaoran is on a distinguished road
Hello everyone! When I want to choose combustion model in Supersonic combustion, I find many paper using Finite-Rate model. So why they use this model but not Eddy-Dissipation model? I thought the Eddy-Dissipation model is the most complex model so there are more details.
ranxiaoran is offline   Reply With Quote
Old   August 27, 2021, 01:08
Lorenzo Galieti
LoGaL is on a distinguished road
Eddy dissipation model is among the cheapest models. It’s not garbage in some situations but in general it is not accurate
LoGaL is offline   Reply With Quote
Old   August 27, 2021, 03:21
Default question
iiran
So what about the Eddy concept model? Is that better than finite-rate or not?
thank you for your reply!
Old   August 27, 2021, 03:44
Lucky
Finite Rate is a laminar flame model and doesn't model any turbulence-chemistry interaction. It works really well when there isn't much turbulence.
Eddy dissipation at least has some model for the turbulence-chemistry interaction. EDC is a more advanced form of EDM for turbulent flames. The problem with EDM and EDC is that they assume the flame burns only as fast as the turbulent mixing allows and cannot proceed as fast as the chemical kinetics might otherwise allow.
So depending on the environment around the flame, one of the models tends to perform really poorly.
Old   August 27, 2021, 03:57
Default Thanks a lot
iiran
Thank you for your reply! I understand it now!
Old   August 27, 2021, 08:24
Lorenzo Galieti
I know in the EDC you can incorporate finite rate chemistry.
Just understand that in combustion there are two time scales: the mixing time between fuel and oxidant, and the reaction time.
The mixing time is almost alwais the dominant between the two. Once mixed, the reaction takes place very fast. So in some cases, it is possible to assume that the burn time is simply mixing dependent. This is what eddy dissipation model does.
In my experience, with EDM you can get something reasonable (not good) in low mach number, high temperature combustion chambers of standard aero-engines, though you accept that you will overpredict the flame temperature. I don't think it is the same story with supersonic combustion.
Old   August 27, 2021, 08:34
Default Thank you
iiran
Yes, I find many papers say that they use the finite rate model but there are no paper use the EDC or EDM. Now I think maybe that is because the burning time and mixing is strongly coupled in the supersonic simulation.
I understand now and thank you for your reply!
supersonic.combustion
Multiphase model and species transport Reginaldo Cotto FLUENT 1 June 6, 2024 05:02
How to set density as constant in species transport model mariam.sara FLUENT 0 October 1, 2019 17:14
Species transport model of platelets and other activating factors Nadun19 FLUENT 0 April 21, 2017 22:18
In CFD how can I employ species transport model to understand 2phase flows jibinbabu28 Main CFD Forum 0 January 5, 2017 01:44
Species transport : how to model a contrast dye in blood vix FLUENT 0 August 13, 2013 11:28
