Results does not converges at higher flow rates |
August 18, 2021, 07:41 |
Faiq Ahmad
Rep Power: 6 |
Hello Everybody!
I am doing CFD analysis to find blood damage inside double lumen cannula used for ECMO. My inner lumen is very narrow with diameter of 1.3 mm. I mesh my lumen with minimum size of 0.02mm. I simulate the case with steady, Viscous laminar (b/c Re= 924), pressure based solver, pressure velocity coupling = SIMPLE, Discretization = Green Gauss Node based, flow rate of 0.00026 kg/sec (velocity = 0.55 m/sec) and everything goes well (I mean results converges upto e-5). Then I change my flow rate to 0.00053 kg/sec (velocity = 1.11 m/sec), my results still converges but take little more time. Then I change my flow rate to 0.00106 (velocity = 2.22 m/sec) and my results are does not converge. I have refined my mesh but that does not work for me instead lead to floating point exception error. I have also checked my mesh quality with maximum skewness and aspect ratio of 0.44 & 6 respectively. What I want to know is why my case converge at low flow rate but diverge at high flow rates. Any kind of help will be highly appreciated and willing to share more information if anybody wants. Pic shows cross sectional view. Thank you 12.jpg |
August 18, 2021, 08:12 |
Lorenzo Galieti
Rep Power: 12 |
Maybe you have to underrelax a bit the equations in the first iterations. It is just reasonable that if you double the velocity, the flow is a little bit trickier to converge.
I would anyways suggest you to use the coupled PV rather than simple, it is much more stable. You may even use the pseudo-transient method in the coupled |
August 18, 2021, 08:43 |
#3 | |
Faiq Ahmad
Rep Power: 6 |
but when I switched from SIMPLE to COUPLES PV, my fluent just crashed (closed by itself) |
August 19, 2021, 06:49 |
This might be a way,
500-1000 iterations in steady state with SIMPLEC with first order upwind accuracy, with relaxation factors Energy eqn (0.9), Pressue eqn(0.3), everything else 0.7 Then switch to your schemes (temporal and spatial) of interest? |
August 23, 2021, 23:49 |
J. Lee
When flow rate is low, the flow is laminar (Re = 924). Now mass flow rate is four times. Then Re = ~ 3,700, then the flow might be turbulent. If so, it is very difficult to get converged solution by using laminar model.
August 25, 2021, 03:09 |
#6 | |
Faiq Ahmad
Rep Power: 6 |
Reynolds Nos for maximum flow rate is 924, which comes under laminar range. |
convergance, convergence fluent |
Very noisy results in the flow around the tube array | Shay_ | FLUENT | 0 | February 22, 2019 07:39 |
Exit Corrected Mass Flow Rate Mesh Sensitivity Study | s__s__s | CFX | 4 | July 20, 2016 12:46 |
inlet has higher pressure than outlet in axial flow fan | sivakumar | Main CFD Forum | 37 | July 21, 2014 09:34 |
Gate valve flow simulations... | nikesh | FloEFD, FloWorks & FloTHERM | 5 | January 28, 2014 02:31 |
target flow rate: varying results | Ryan | FLUENT | 3 | January 9, 2008 14:54 |
