how to write the journal file to output the moment of blades in monitors on cluster? |
August 18, 2021, 05:04 |
Cheng Biyi
In GUI, I have already define the physical quantities that I want to monitor during the calculating. At the same time, I have set the 'report file' in the 'monitors' in GUI which have included the moment of blades.
This set in GUI is valid in the Windows System where I can get '.out' file containing the moment of blades during the whole calculating process. However, the same case and data file uploaded in Linux Cluster cannot output the information that I need to monitor. If anynoe can answer this question? I will give million thanks. Last edited by Cheng Biyi; August 18, 2021 at 05:07. Reason: To be more specific. |
.out file, cluster, moment of blades, monitors, report file |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 07:47 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 06:18 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
