August 15, 2021, 20:51 |
How to set velicoty inlet with an angle
Huihua Yang
Rep Power: 5 |
Hi guys,
I would like to simulate a 2D problem. My velocity inlet should be 0.25 m/s with an angle of 5 to the normal. I use the 'component' options in the velocity inlet, which means the x component = 0.02179m/s and the y component equal to 0.249m/s. In my simulation, I would like the velocity component to be a constant. I choose the reference frame to be 'absolute'. But it seemed that ansys gave me a result of moving frame and the track of the inlet fluid looked like a 'rotated' jet. I would like a straight jet with an angle of 5 degree to the normal. Does any one know how to solve it? Thank you very much for your help. |
August 19, 2021, 08:59 |
velocity inlet
iiran
Rep Power: 5 |
Why not choose the 'magnitude and direction' item in Velocity Specification Method?
August 19, 2021, 14:53 |
Huihua Yang
Rep Power: 5 |
August 20, 2021, 14:12 |
Rep Power: 26 |
Can you show a picture of your flow field? I don't understand your description of a warped jet...
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
August 23, 2021, 13:32 |
#5 | |
Huihua Yang
Rep Power: 5 |
The jet should leave the inlet interface with an angle of 5 to the nominal. But it seems not like that. BTW, there is a vapor at the top of the model. I thought it might be the existence of the vapor that bounded the jet flow. jet flow.png |
August 23, 2021, 16:02 |
Lorenzo Galieti
Rep Power: 12 |
Hi, from the flow field it seems to me that it is leaving at 5 degrees, but then creates that weird structure. I don’t think there’s a mistake with the velocity inlet BC, there’s something else more fishy going on
How to properly set pressure inlet pressure. | ansys_matt | Main CFD Forum | 10 | March 11, 2021 06:48 |
How to set fully developed flow aty inlet? | FernandoSoares | OpenFOAM Running, Solving & CFD | 7 | November 18, 2016 00:16 |
[mesh manipulation] mirrorMesh and undoing the joining of patches | chegdan | OpenFOAM Meshing & Mesh Conversion | 3 | October 21, 2015 08:09 |
UDF to set velocity and pressure in inlet | GerardX89 | Fluent UDF and Scheme Programming | 0 | July 16, 2012 10:15 |
