How to export temperature file in just one cell zone? |
Luca Ronzani
Rep Power: 0 ![]() |
Hi everyone,
I am doing a transient simulation in Fluent and I am trying to export temperature and cell volume data of a specific domain to post process it in Matlab. I defined it with a cell zone but I can't export the entire cells in volume. There are 2 ways. If I select nothing while exporting, Fluent gives me all the cells in my simulation and this is a problem for me because I can't use it. If i select only the cell zone I want, what I obtain are the cells value only in surface (I think), but i want it in all the volume. (The total number is 360'000 and i can see just 33'600 cells.) I did many attempts but no results. I also tried to delete other cell zones but Fluent don't allow me to do It and it crashes. (I think because I set shell conduction) I hope you can help me, Thanks in advance Luca |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
File=>Export=>Solution Data and just choose the cell zone but don't select any surfaces.
There are also more faces than cells, so if you think you see fewer face values than cell values, that's also just plain wrong. |
Luca Ronzani
thanks for your reply but let me explain better. As you can see in the photo i attached, if I want to export file in ascii format, Fluent doesn't allow me to select directly the cell zone (I can t understand why). So I have to select the zone i want in the other section but this doesn t work. |
Lucky
Definitely do not select anything in the middle surface column, doing so will indeed not export volume data and give you surface data. Older versions of Fluent there wasn't even a selection for cell zones & you could only dump all the cell zones. Maybe it's not doable for you this way.
A workaround is to write an interpolate file. File=> Interpolate. Here you can select individual cell zones and individual variables to export. And this works in just about all versions. |
cell zones, export, single cell zone |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
