Help with UDF for Hinged Leading and Trailing Edge Deflections |
August 12, 2021, 14:59 |
Minnesota
Rep Power: 5 |
Hi Everyone,
I am new to Ansys Fluent and UDF's but have ample experience in CFX. I need to simulate the motion of a moving leading/trailing edge deflection on an airfoil. I will have a non-rigid body so I know I need to use the Grid_Motion macro. I was wondering if anyone can help me set up the UDF. I need to specify the x location for the motion at 25%c and 85%c for leading and trailing edge respectively. I need to set a max deflection of 6 degrees. I need the amount of deflection per timestep to be specified by a equation of motion which I don't have yet but I will. If anyone is able to help me with this I would greatly appreciate it. |
airfoil, fluent, morphing, moving, udf |
Meshing near leading and trailing edge of propeller | surajp92 | STAR-CCM+ | 1 | June 1, 2017 01:40 |
[ICEM] Sharp leading and trailing edge airfoil | matters_100 | ANSYS Meshing & Geometry | 10 | April 5, 2016 14:20 |
Leading edge and trailing edge of an airfoil rotor blade | Jun_Milan | CFX | 0 | July 10, 2014 23:07 |
Y-Plus values at aerofoil leading edge and trailing edge at high incidence | Engr07 | Main CFD Forum | 4 | June 29, 2012 10:42 |
[DesignModeler] Creating a blunt trailing edge from collapsed leading edge | gmd | ANSYS Meshing & Geometry | 0 | March 2, 2012 09:48 |
