Static temperature remains constant in a combustion simulation
Old   August 10, 2021, 05:10
Default Static temperature remains constant in a combustion simulation
Khadorna is on a distinguished road
Hi, i've been trying to get a combustion simulation of a hydrogen/methane mixture working by using the reduced GRIMECH 3.0 kinetics and transport given by fluent. The transport properties seem to work correctly as the contours for the system show expected results.
I need to get a contour of the static temperature, but it only varies in like 0,5K and i don't really know why as im trying to simulate combustion. With the individual components and a simpler mechanism, it works just fine.
Should I deactivate the tracking of the reaction intermediates? Is something wrong with the thermo file?
Thank you in advance
Khadorna is offline   Reply With Quote
Old   August 10, 2021, 19:37
Lorenzo Galieti
LoGaL is on a distinguished road
So the species distribution is reasonable but the temperature is not? Is it cold everywhere as if there was no flame?
LoGaL is offline   Reply With Quote
Old   August 11, 2021, 04:07
Exactly. The species distribute accordingly I think, but temperature (set at 300K) does not increase anywhere in the system.
I've tried to reduce step time, increase the number of iterations, but that point converges and Fluent does not get anywhere else.
Old   August 11, 2021, 06:40
Lorenzo Galieti
Usually you need some manner to kickstart the combustion, a sort of numerical spark if you want.
So basically, you should patch (i.e. impose) the combustion chamber region with a high temperature (1800K) once the cold flow is properly developed, as in your case. Just google “fluent patch region” and you should find plenty of instructions on what to do
Old   August 12, 2021, 05:51
I've tried patching a small region of the combustion chamber with a high temperature, kind of emulating a spark as you said, but the result did not change at all. Should i patch a bigger region of the combustion chamber? (maybe like half of it?) or should it work with what I set up?
Thank you for your help
Old   August 12, 2021, 06:45
Lorenzo Galieti
I usually patched the whole combustion chamber . If you see it diverges, either underelax a bit the equations for 20-30 iterations or, if you are using pseudo transient method, set a lower multiplicator
fluent, grimech, static, temperature
Enthalpy Residuals remains constant even though Temperature is converged pss47 OpenFOAM Running, Solving & CFD 5 November 13, 2018 11:45
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Static Simulation Result on 1D Mesh - CoalChemistryFoam DustExplosion OpenFOAM Running, Solving & CFD 6 September 30, 2016 12:10
Static temperature and Total temperature Jong-Yoon FLUENT 0 September 25, 2016 02:42
Tf is averaged by static or total temperature ?? NPU_conanxie Main CFD Forum 0 April 6, 2011 22:30
