August 8, 2021, 15:32 |
Nusselt number
Rep Power: 5 |
Hi guys, I'm doing a project that consist in a 2D, laminar, stationary problem. It is a microchannel with wavy/corrugated walls that are hotter than the inlet. The thing is that I have to study heat transfer in this walls and I don't know how to get Nusselt number and heat transfer coef. (h). I've tried the "mass-weighted average" thing but I think that values are not correct.
Thanks beforehand, I will appreciate any type of help. |
August 11, 2021, 09:36 |
Rep Power: 5 |
Hi guys, so I think I found a solution to do this, but I don't know if I'm doing it the correct way, even I think I'm doing it well.
In CFD-post, "solution" in Workbench, I obtain some parameters in order to calculate Nusselt Number with Excel. I'm obtaining Twall, Tmean and heat flux. I know temperatures are well, but I don't know 100% if I'm obtaining heat flux properly. I got Wall Heat Flux by creating a point and then, in expressions, putting "maxVal(Wall Heat Transfer)@Tw" -being "Tw" the point that I created before and which is in the wall, at the point that I want Wall Heat Flux value. If you can give some tips or confirm my method I will apreciate it so much. Ty. |
heat, heat transfer, micro channel, nusselt number |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 10:15 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
