August 6, 2021, 09:05 |
Recirculation B.C./ SIGSEGV
Mohammad Fathi
Rep Power: 6 |
I want to to apply recirculation boundary to two edges of my 2d geometry. I have used the following code in TUI. (rpsetvar 'icepak? #t) (models-changed) Although the recirculation B.C. are active now, however,, the solver cannot proceed anymore. The Error: Received Signal SIGSEGV. I have tried both serial and parallel processing. I have also changed the core number, but none of them works. Do you have any suggestion?? Regards, Mohammad. |
recirculation, sigsegv |
Recirculation Outlet DPM Boundary Conditions | afiefaldy | FLUENT | 2 | December 21, 2023 05:08 |
what is difference between recirculation region, eddy field and vortex? | fruitkiwi | Main CFD Forum | 14 | January 1, 2021 14:43 |
error: Received signal SIGSEGV | ianziti92 | Fluent UDF and Scheme Programming | 2 | December 5, 2018 17:25 |
Urgent! Help on UDF to set B.C. of 3rd type | Ray Hong | FLUENT | 0 | December 28, 2005 20:35 |
How to set B.C. of the 2nd or 3rd type in UDS? | Ray Hong | FLUENT | 0 | December 28, 2005 07:03 |
