Inlet diffusion enhances convergence in ansys fluent? |
gionin
Rep Power: 0 ![]() |
Hi everyone,
I'm simulating a cylindrical volume with axis in z-direction. This volume is closed at the top and open at the bottom. It's filled with helium and gravity is applied, with ambient conditions outside of the cylinder (air). I want to simulate the diffusion process in the cylinder. My setup is as follows: Pressure-Based, transient simulation, in 2D space with gravity enabled Energy off Viscous laminar Species transport with inlet diffusion enabled Boundary conditions: -Pressure outlet with reverse flow -Cylinder as wall with zero diffusive flux Method: SIMPLE Now my question: No inlet is defined, but still my solution converges much faster with the option "inlet diffusion" enabled. With inlet diffusion disabled it doesn't converge at all. How is that possible? Thank you for your help. Last edited by gionin; August 5, 2021 at 08:01. |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
It doesn't have to be an inlet type, stuff just needs to be moving in. Your pressure outlet with reverse flow is an inlet. Even without reverse flow it can still be a species inlet. Stuff can still diffuse inwards even without stuff flowing inwards.
gionin
Hi LuckyTran
Thank you for your answer. Ok, I got confused with the different meanings of "inlet". So my simulation setup and the results should be reasonable considering they correspond quite good to the experimental values. |
diffusion, fluent, species transport |
Ansys Fluent UDF, Wall Average Temperature Depend On Inlet Velocity | ozgeozge | Fluent UDF and Scheme Programming | 1 | April 15, 2019 01:31 |
Using inlet mpi in parallel ANSYS fluent with AMD processors | freebird | ANSYS | 1 | June 16, 2017 09:04 |
2D Hypersonic Inlet in FLUENT - Convergence Issues | Fraisdegout | FLUENT | 6 | December 15, 2016 02:07 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
