July 14, 2021, 09:43 |
Setting velocity UDF at outlets
sofia
Rep Power: 5 |
I have a coronary artery and I am trying to implement a UDF of pressure in the inlet (pressure-inlet type) and a velocity profile in the outlets (mass-flow-outlet type). I understand that velocity and mass flow rate are different things, but the profile shape is the same (just different magnitudes).
This approach is inspired by Fig. 4 of an article (https://doi.org/10.1080/10255842.2014.921682). I can implement the inlet pressure, but I cannot define the outlet velocity... the closest is mass flow rate which I selected. When I run the calculation, Fluent returns the following error: Error: / (divide): invalid argument [1]: wrong type [not a number] Error Object: inf. I have tried doing the opposite (inlet velocity and outlet pressures) and there are no errors... Any help? Thanks in advance |
July 15, 2021, 14:18 |
Lucky
Rep Power: 66 |
Not sure what your error is. Check your UDF. But you can specify the velocity if you use a velocity inlet type BC at an outlet. The BC type may be named an inlet but it is a fixed velocity constraint.
boundaries condition, error, inlet, udf, velocity |
serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 09:56 |
UDF for inlet velocity alongwith UDF for properties | akshayy224 | FLUENT | 0 | February 1, 2018 10:17 |
3-D parabolic velocity Inlet - Steady state - UDF Turbulent Flow | mohibanwar | Fluent UDF and Scheme Programming | 10 | May 18, 2015 11:34 |
Simulation with UDF for species mass fraction and velocity profile | virgy | Fluent UDF and Scheme Programming | 8 | February 7, 2012 05:30 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
