Annulus Flow Through Multiple Inlets and Outlets, Fluent (Student) |
July 7, 2021, 16:43 |
Jk
Rep Power: 5 |
Case Setup: I'm doing my first fluid analysis in FLUENT where I'm trying to set up a case with 22 inlets and 22 corresponding outlets within an annulus, all on the same plane (in symmetry). The fluid is air and is assumed laminar, all inlets experience the same physical effects. Problem: In "Cell Zone Conditions" and "Boundary Conditions", I get a very messy layout where I have problems assigning the proper values to the right geometry. My Approach To the Problem: Different configurations with regards to geometry setup have been tested, such that I can apply proper boundary conditions in "Setup". Figure_1 displays my latest approach where I sliced the bodies in the middle plane, such that I can apply different names for outlet and inlets. (See Figure mesh setup). My Question(s) Are:
My goal is to find the flow rate and velocity and compare it to an exact copy but with a different (not circular) geometry. Thank you for your time and help |
July 9, 2021, 04:19 |
Resolved
Jk
Rep Power: 5 |
This has been resolved. Since I've only been working with OpenFOAM, I realized that with regards to geometry formation, it's the fluid domain that needs to be modeled. (i.e., caps/lids as in Solidworks fluid simulation or OF is not the way to do it)
Flow Distribution of a Single Inlet in a Multiple Inlet&Outlet Flow | nytek | FLUENT | 0 | March 29, 2021 05:33 |
Is this project converged? (Imbalance mass flow rate between outlets and inlets!) | Roh | FLUENT | 2 | August 31, 2018 00:56 |
2 inlets, 2 outlets. Assessment of flow rate ratio. | Jiricbeng | CFX | 9 | May 22, 2018 06:29 |
OpenFOAM - Multiple inlets / outlets | C. Okubo | OpenFOAM | 0 | April 26, 2018 18:51 |
rate flow FLUENT | rayan24 | FLUENT | 3 | July 25, 2013 04:26 |
