Help regarding Intel MPI in ANSYS Fluent
Old   July 1, 2021, 07:34
Default Help regarding Intel MPI in ANSYS Fluent
Kamran
KayZee2031 is on a distinguished road
Hi! I'm a bit new to CFD so please forgive my ignorance. I've been, for a while, trying to get Intel MPI to work over a few core i5 PCs. On a fresh install, all worked well for ANSYS CFX though after a few months when I tried to do the same using Fluent, it didn't work. And yes I understand both use different format files (I followed the steps you find on the internet). The consensus of my colleagues is that one shouldn't change the PC's password after starting MPI for the first time. Also, the error I get at the start of a simulation is something regarding authentication. I've tried freshly installing ANSYS back again but it doesn't work. All the PCs are similarly speced and ANSYS is installed in the same directory for every PC.
Can anyone help? I do believe there should be something that can be done within the source files that'll get it fixed, though I can't find anything.
KayZee2031 is offline   Reply With Quote
fluent, mpi, parallel, parallel calculation
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 04:17
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 11:54
