Marcin
Rep Power: 13 ![]() |
Hello I have question. Im doing a simulation with rotating domain (black frame) (with fan inside).
I defined 57 rad/s on rotating domain with rotating walls of fan and rotating wall interface. On the stationary domain I only define rotation (0 rad/s value) on the interface. Why on the borders of domains (white frame ) I dont have smoothh transition of velocity plot???
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
Marcin
anyone know why this happening ???
Marcin
Is that a problem in postporcessing ????
Is I need to pick Velocity in STn Frame to plot real distribution of velocity values in MRF ort Sliding MEsh models ????
Vestdam
Rep Power: 8 ![]() |
Yes, I believe you should present the results as velocity in stn. frame in CFD Post.
Is it a 3D model? The velocity field in the stationary domain seems a bit patchy and strange. Is it fully converged? /vestdam |
Marcin
Yes this is 3d .
Yea Ur right this model isnt full converged . Full simulation with sensivity analysis i do now. But in both situation mrf and sliding mesh velocity will be non continous. Only velocity stn frame will be representative ???
Marcin
And I have additional question for the calculation of forces on the fan I need to make sliding mesh method with transient or only need is to make mrf with steady state ???
Vestdam
I would always use Velocity in Stn frame in CFD post..
For force analysis, I am in the same boat as you. So far I get much better results with transient analysis compared to steady state. /Vestdam |
Marcin
thank U for the answer
Best regards
using outlet velocity profile as inlet for next set of iterations | tricha122 | FLUENT | 0 | November 22, 2020 09:40 |
Problem with Velocity Poisson Equation and Vector Potential Poisson Equation | mykkujinu2201 | Main CFD Forum | 1 | August 12, 2017 13:15 |
atmBoundaryLayerInletVelocity - Velocity Profile not continuous through domain | sdfij6354 | OpenFOAM Running, Solving & CFD | 3 | July 26, 2017 16:16 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
