Species Mass Transfer - results keep diverging
Old   June 29, 2021, 01:10
Default Species Mass Transfer - results keep diverging
Stanlee
stanlee8 is on a distinguished road
Hi everyone,
I am trying to simulate the natural evaporation of a thin water film. Basically, there is dry air passing through above the water liquid film, and the water liquid is expected to evaporate into the dry air. Basically, I wanna reproduce the simulation in this link (https://www.youtube.com/watch?v=uuIq...annel=AkiraIto).
I used the Eulerian Multi-Fluid VOF model, with the first phase being a mixture of air and water vapour, the second phase is also a mixture but only contains water liquid. I used the species mass transfer and kept the saturation pressure as default. The pics show the settings and boundary conditions. The result diverged almost immediately after the simulation began. The time step is 0.00005 s, so the courant number is no way greater than 250.
If I did not patch the water liquid in the domain, it worked without any errors.
Please help me!! Thank you!
The errors show below:
Error at Node 2: Global Courant
Error at Node 4: GlEE
Error at Node 5: Global Courant number is greater thr number is greater rothan 250.0an 250.00 The
vel0 The
velocitocityyr field atrror a Nod f is probably diverging. Please cheeield is pt 1 Node ck the solution
0: Global Couraand reduce the time-stent number is greater p if necessthan 250.: Global Cary.
00 ouobal Courarnt nant number is greumber isater t ghan 250.00 The r
velocity fe ield isThe
velocit probablyy fiel divergid is probng. Pleaseably d check tiverging. Plehe solution
and redase check the solution
and reduce the time-step if necessary.
ater than 250.00 The
velocity field is probably diverging. Please check the solution
Error at Node 3: Global Courant number is greater than 250.00 The
stanlee8 is offline   Reply With Quote
Old   June 29, 2021, 08:40
Lorenzo Galieti
LoGaL is on a distinguished road
Did you try to reduce the timestep a lot? Look that a courant of 250is freaking high for complicated physics like the one you are simulating
LoGaL is offline   Reply With Quote
Old   June 29, 2021, 17:16
Stanlee
Hi Logal,
The current time step is 0.0005, mesh size is 0.002, velocity is 1 m/s, so the courant number should 0.025..it is low enough i think.
Old   June 30, 2021, 18:09
Lorenzo Galieti
Sorry man but I read 250 in the log you are posting, clearly something you miscalculated?
multiphase, species mass transfer, vof
mass fraction of species Lilly FLUENT 5 March 13, 2022 18:52
What is the equation or formula to calculate Mass Flux[kg/m²s] of species in Fluent? THA SEANGHAI FLUENT 0 September 11, 2020 02:10
Species mass transfer in bioreactor jayorayo FLUENT 4 May 29, 2018 18:44
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
mass transfer coefficient for boundary condition niek Main CFD Forum 0 March 29, 2011 06:33
