Stanlee
Rep Power: 8 ![]() |
Hi everyone,
I am trying to simulate the natural evaporation of a thin water film. Basically, there is dry air passing through above the water liquid film, and the water liquid is expected to evaporate into the dry air. I used VOF and enabled the sharp interface and interfacial anti-diffusion, as well the evaporation-condensation Lee model. However, as the picture shows, the interface between the water liquid and the air (the air is the mixture of water vapour and dry air) is not "sharp" at all. Instead, there is a gradient of volume fraction of water liquid. How could this be? I expected the interface should only occupy one layer of cells, which mean except for one layer of cells, other cells should be either 0 volume fraction of water liquid or 1 volume fraction. Could somebody please help? Thanks Regards ![]() |
Lorenzo Galieti
Rep Power: 12 ![]() |
You are using interpolation in the contour, you should check cell values instead.
Substantially, if in one cell your volume fraction is 1 and in the next is 0, if you use interpolation in the contour, you will see a gradient from 1 to 0, if you show cell values, this does not happen |
Stanlee
Dear LoGap,
Thanks for your comments, but could you please tell me how I can check the cell values? |
Lorenzo Galieti
I think you should disable “node values” before plotting the contour
Stanlee
Cool, I have tried it up and it seems to work.
Let's c what will happen. Thank you! |
vof; multiphase |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
How to apply heat flux at the interface when using VOF method? | princekar | FLUENT | 0 | November 15, 2015 07:47 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
