Dimji199
Rep Power: 5 ![]() |
Hello everyone, I have tried to simulate a cyclone separator with ANSYS Fluent. In setting solution in Workbench I have followed the steps and instructions according to the validation journal. However, my simulation tangential velocity contour results are different from the validation journal. In the validation journal the tangential velocity contour on the center of cyclone should be low but in my simulation contour it is high. However, the contours of the pressure drop and the axial velocity are appropriate.
Note : I used reynold stress turbulence model (RSTM) and Discrete Phase Model (DPM) to injection modeling Can you help me solve this problem? |
Marcin
Rep Power: 13 ![]() |
do U define gravity ??? Maybe check this first
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
Dimji199
Thank you Mr Martin. Yes, i am already define gravity in y axis. But this contour still don't change.
cyclone separator, tangential velocity |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 08:35 |
tangential, axial and radial velocity in swirling | Al-Hashimi | FLUENT | 1 | June 23, 2013 10:30 |
Tangential velocity - Theoretical and the one used in different CFD softwares | maheshraj | Main CFD Forum | 1 | October 29, 2012 13:34 |
Cyclone Tangential Velocity ... | Abdul | FLUENT | 2 | August 13, 2008 00:07 |
tangential velocity on a velocity inlet in 2D | bretti | FLUENT | 0 | July 3, 2007 08:42 |
