Adithya
Rep Power: 5 ![]() |
Hello
I am working on a simulation using ANSYS meshing and Fluent. The problem statement is like this. I have an object within its own small control volume. I will create a bigger separate control volume in another mesh and remove the volume for the smaller control volume with the object. In Fluent, I will append the meshes. I will merge all cell zones into 1 fluid domain. I will either fuse or create interfaces at the common faces. My problem is: I need to perform studies by rotating the outer mesh upto 10 deg. I intend to rotate the mesh after importing it to Fluent by using the Translate/Rotate option available. After I rotate the outer mesh, will it still be possible to fuse the common faces even if they intersect? Is there another way to make the mesh 'modular' so that I can replace parts and rotate them as needed? |
[snappyHexMesh] snappyHexMesh stuck when snap is turned on | yukuns | OpenFOAM Meshing & Mesh Conversion | 3 | February 2, 2021 13:05 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
Divide Prismatic Boundary Layer Mesh causes overlapping faces | SilentRunner42 | enGrid | 4 | May 4, 2015 03:37 |
[ICEM] Merge mesh - non manifold vertices | BrolY | ANSYS Meshing & Geometry | 4 | October 30, 2010 22:07 |
