To print report-definitions data to .out files using journal file
Old   June 23, 2021, 03:49
Default To print report-definitions data to .out files using journal file
AMIRHOSEIN
amir007 is on a distinguished road
Dear all,
I am running a Fluent case file using a journal file on the cluster. I have defined some parameters in the report-definitions in the case file and on my pc, I can get .out files but it does not output anything on the cluster. Here is my journal file:
parallel/partition/auto/use-case-file-method yes
file/read-case case14.cas
define/user-defined/interpreted-functions "case14.c" "cpp" 10000 no
parallel/partition/print
solve/initialize/initialize-flow
solve/report-definitions
file/auto-save/data-frequency 1
file/auto-save/append-file-name-with time-step 10
solve/set/time-step 1e-1
solve/dual-time-iterate 100000 30
file/confirm-overwrite no
file/write-data case14.dat.gz
exit yes
and the line in question is in red. I wonder if you could please help me with this.
amir007 is offline   Reply With Quote
report definition
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 15:30
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
