Changing flow Mach No. by changing Pressure Outlet in Pressure driven supersonic flow
Old   June 20, 2021, 18:09
Default Changing flow Mach No. by changing Pressure Outlet in Pressure driven supersonic flow
Priyank Goel
Goel is on a distinguished road
I am simulating the supersonic flow inside a wind tunnel section with top and bottom as walls (Boundary condition). In this, the flow is pressure-driven with high inlet pressure to low pressure at outlet.
I use pressure inlet BC at inlet and pressure outlet with 0 static pressure at outlet. Then after 1st result I raised the outlet temperature but there is no change in flow noticed.
Goel is offline   Reply With Quote
Old   June 21, 2021, 17:53
Lucky
The outlet temperature is not invoked unless there is reversed flow, and there shouldn't be any reversed flow in a wind tunnel. That's why changing the outlet temperature does nothing.
Old   June 22, 2021, 05:48
Priyank Goel
So how can I vary the flow Mach No. from the initial 2.5 to ultimately stopping the flow?
mach reflection, shock reflection
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Compressible Flow Pressure Outlet Back Flow okstatecheme OpenFOAM Running, Solving & CFD 1 March 21, 2018 09:11
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions Vishnu_bharathi CFX 12 November 21, 2017 07:56
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
