How does FLUENT caculate velocity profile at wall when shear is specified?
Old   June 4, 2021, 09:54
Default How does FLUENT caculate velocity profile at wall when shear is specified?
Faizan
Faizan89 is on a distinguished road
Dear all,
I am doing simulations for laminar flow in a 2D rectangular channel where a wall is modelled with specified shear (against the flow direction using a udf prescribed profile (for example using linear or sinusoidal functions.) Although, the udf profile works fine and the wall shear stress remains as specified, I am not able to understand how does Fluent calculates the corresponding velocity profile at the wall. I have tried comparing velocity profile from Fluent with that calculated using integration of tau=mu *du/dy but the velocity is significantly smaller in FLUENT.
Does anybody know how does velocity profiles is implemented in FLuent when shear stress is specified?
Regards,
Faizan
Faizan89 is offline   Reply With Quote
Old   June 4, 2021, 20:13
Lorenzo Galieti
LoGaL is on a distinguished road
Which viscosity did you use? Are you perhaps running a turbulence model?
LoGaL is offline   Reply With Quote
Old   June 5, 2021, 13:04
Faizan
Hi Lorenzo,
I have tried constant viscosity as well as temperature dependent viscosity using udf (not needed for base case with only flow) for this case. I am not using any turbulence model. My flow strain calculation is correct given as du/dy=stress/viscosity but apparantly Fluent is calculating velocity in some different way. Any ideas?
Regards,
Faizan
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 07:45
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Shear stress from velocity profile baranii2000 COMSOL 4 November 11, 2015 05:08
Velocity profile interpolation FLUENT Mustafa1986 FLUENT 3 April 28, 2015 04:23
Influece of wall velocity in the main flow marvin CFX 0 March 22, 2008 03:05
