June 1, 2021, 10:25 |
Vertical Axis Wind Turbine Simulation
amin
Rep Power: 5 |
Hi friends
I have little knowledge of CFD and Fluent. I have questions about simulating a vertical axis wind turbine in Fluent. Problem specifications are as below: * 3 blades H type VAWT * 2D simulation * Unsteady * wind speed= 5 m/s * Tip Speed Ratio= 1, 1.5 , 2 , 2.5 , 3 * time step size= 0.0001 s * K-omega SST model How can I calculate and check "Y+" in Fluent? How many "time step" is required to the problem converges? How many "iteration per time step" is required? How can I calculate the "average torque coefficient"? I know that the torque coefficient= torque/(0.5*rho*v^2*A*L) but I don't know how I can calculate and save it in the Fluent software. Thanks Last edited by amind; June 1, 2021 at 13:43. |
time step, torque coefficient, vawt |
How to average the torque coefficient for vertical axis wind turbine? | NotOverUnderated | FLUENT | 2 | September 6, 2022 14:55 |
Modeling a vertical axis wind turbine / Negative momentum coefficient | Felipe06 | FLUENT | 0 | January 24, 2019 17:19 |
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) | tony00 | FLUENT | 11 | July 23, 2018 06:13 |
Vertical Wind Turbine rotor simulation | victorb | CFX | 6 | May 29, 2016 07:31 |
Vertical Axis Turbine Simulation | dalecooper | FLUENT | 3 | July 24, 2013 08:53 |
