Very High Coefficient of Pressure Values for Flow Pas a Circular 2D Cylinder
Old   May 28, 2021, 06:57
Default Very High Coefficient of Pressure Values for Flow Pas a Circular 2D Cylinder
SS
n0t_sm0L is on a distinguished road
Hello CFD Community,
I'm relatively new to Fluent, and I'm performing a 2D analysis of a flow past a circular cylinder as a part of my project. The cylinder is 6 mm in diameter and the inlet velocity of 20 m/s, making the Reynold's number 7638. The drag coefficient value is around 1.97, which agrees with literature, while the coefficient of pressure value is ridiculously high. I've used a tri mesh, with 50 layers of inflation at a growth rate of 1.2. The first element size was calculated to be around 1e-5 for a y+ of 0.8, to capture boundary layer effects.
The Cp vs length plot shows values of 500, which is much too high. I also plotted cp vs theta upto 180° (since fluent plots against length), and have attached it herewith. The nature of the graph appears okay I think, but can anyone please help me with why the cp values are so high?
Thanks so much in advance
n0t_sm0L is offline   Reply With Quote
ansys 2020, cylinder flow, external aerdynamics, flow past cylinder, fluent
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
error message cuteapathy CFX 14 March 20, 2012 07:45
base pressure for circular cylinder fpz Main CFD Forum 7 June 20, 2005 22:30
