May 22, 2021, 21:48 |
Residuals not decreasing!
Ali
In a pipe reaching a bifurcation simulation, with first-order upwind I have no problems with residuals, and they decrease normally, then after convergence, I switch from first-order to second-order upwind, the residuals remain constants and oscillating at 10e-2.
I refined my mesh, I used different schemes (simple,...), but nothing changed. Why? What I have to do to solve this problem Just as a short description: Geometry is shown in the attached picture For the mesh: in the root, the element size is: 0.6 mm in the red sphere zone, the element size is: 0.3 mm for the boundary layer, the first layer thickness is 0.08, number of layers: 5, growth ratio: 1.2 the minimum orthogonal quality is 0.15 and the highest skewness is 0.84! inlet B.C: parabolic Velocity profile: 2*V_mean*(1-(r*r/(R*R))) outlet B.C: pressure outlet: 13332 pa Scheme: coupled Steady-state Thanks! |
Residuals start increasing after decreasing to a very low value | The_seeker | Main CFD Forum | 22 | April 18, 2023 13:46 |
Cannot find functionObject file residuals | vava10 | OpenFOAM Pre-Processing | 2 | November 14, 2020 12:21 |
Residuals decreasing in the beginning and then increasing --MRFSimpleFoam | kingmaker | OpenFOAM Running, Solving & CFD | 0 | February 10, 2014 09:22 |
residuals keeping decreasing in linear way | solefire | Main CFD Forum | 1 | August 12, 2009 04:12 |
Decreasing residuals | Robert | FLUENT | 6 | June 25, 2003 01:26 |
