Does FLUENT use linearized Navier-Stokes equation with all convection terms removed? |
May 19, 2021, 04:14 |
Sripadaraja
Rep Power: 11 |
It is said that when Reynold's number is much less than 1 (Re << 1), convective terms can be removed/neglected. Does ANSYS Fluent neglect/remove convective terms during computations in such a case?
May 19, 2021, 17:55 |
Lucky
Rep Power: 66 |
No. It sticks to the same equations.
Furthermore, the general (dimensional) Navier-Stokes equations doesn't have a Reynolds number in it. Without a meaningful velocity scale and length scale, there isn't any notion of Reynolds numbers and no way to know when to remove these terms or not. Also be careful what you read because more often than not, linearized Navier-Stokes does not refer to eliminating convective terms. Linearized Navier-Stokes is linearizing the non-linear convective term about the perturbation order, neglecting higher order terms, and hence linearizing it. The Stokes equations, although they are deduced from the N-S equations and are linear, are generally not called LNSE. |
convection term, fluent, laminar flow, reynolds number |
rotational and inviscid | Mike | Main CFD Forum | 40 | November 9, 2023 07:03 |
Help about Implicit navier stokes equation solver | kamaljannati | Main CFD Forum | 0 | June 8, 2019 17:53 |
Matlab CFD Complete Navier Stokes equation | archeoptyrx | Main CFD Forum | 1 | July 11, 2013 10:24 |
Newbie:Viscoelasticity and Navier stokes equation | Rajil Saraswat | Main CFD Forum | 2 | June 9, 2003 08:21 |
K-Epsilon model? | Brindaban Ghosh | Main CFD Forum | 2 | June 24, 2000 05:22 |
